9 years agoBist code for integer based arithmetic and logical operation
HELLO, Its PLEASURE this kind of medium TO FOR DISCUSSION OF PROBLEM REGARDING VERILOG CODE. I am beginner of the Verilog and i am learning verilog, how to call module write testbench..etc ...
9 years ago --- Quote Start --- We can help you with YOUR code, not write it for you. Post the code you are having a problem with. Cheers, Alex --- Quote End --- thank you sir but i had made code which is only pattern generator and fault inserting accept the signature analyzing.... can you provide me code for signature analysis or guide me how i give output of cUT and that give to MISR(MULTI INPUT SIGNATURE REGISTER). and how MISR will give golden response so I can compare and find the response is good or not . so i can decide whether my alu is faulty or not .
