9 years agoBi Directional pins
Hello all I am trying to utilize bi-directional ports of the inout type for the first time. I found the following code on the Altera website. https://www.altera.com/support/support-resources/...
9 years ago --- Quote Start --- Thanks Kaz I don't think its a sampling problem. For example the inp to a register and outp to b register all works fine. The birdir just does not ever show anything other than undefined. Do you see any issues with how the testbench is driving the bibir line through inp? --- Quote End --- It seems that example model is wrong. look t my changes:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY bidir IS
PORT(
bidir : INOUT STD_LOGIC_VECTOR (7 DOWNTO 0);
oe, clk : IN STD_LOGIC;
inp : IN STD_LOGIC_VECTOR (7 DOWNTO 0);
outp : OUT STD_LOGIC_VECTOR (7 DOWNTO 0));
END bidir;
ARCHITECTURE maxpld OF bidir IS
SIGNAL a : STD_LOGIC_VECTOR (7 DOWNTO 0); -- DFF that stores
-- value from input.
SIGNAL b : STD_LOGIC_VECTOR (7 DOWNTO 0); -- DFF that stores
BEGIN -- feedback value.
PROCESS(clk)
BEGIN
IF clk = '1' AND clk'EVENT THEN -- Creates the flipflops
a <= inp;
outp <= b;
END IF;
END PROCESS;
PROCESS (oe,a,b,bidir) -- Behavioral representation
BEGIN -- of tri-states.
IF( oe = '0') THEN
bidir <= "ZZZZZZZZ";
b <= bidir;
ELSE
bidir <= b;
b <= a;
END IF;
END PROCESS;
END maxpld;
