9 years agoBi Directional pins
Hello all I am trying to utilize bi-directional ports of the inout type for the first time. I found the following code on the Altera website. https://www.altera.com/support/support-resources/...
9 years agoI note your clock is 1 us period but your waits are 500 then 1000 or so ns. You may run into sampling troubles (delta delay etc.)
also check that lower module is indeed found &bound
