9 years agoBi Directional pins
Hello all I am trying to utilize bi-directional ports of the inout type for the first time. I found the following code on the Altera website. https://www.altera.com/support/support-resources/...
9 years agoHere is the testbench. I updated it to add initial condition for the inp and outp signals, but it still does not work.
In this code I was only trying to send a signal to the inp and have it appear on the bidir. Thanks for your help! library ieee; use IEEE.STD_LOGIC_1164.ALL, ieee.numeric_std.all; entity bidir_test is end entity bidir_test; architecture verify of bidir_test is component bidir PORT( bidir : INOUT STD_LOGIC_VECTOR (7 DOWNTO 0); oe, clk : IN STD_LOGIC; inp : IN STD_LOGIC_VECTOR (7 DOWNTO 0); outp : OUT STD_LOGIC_VECTOR (7 DOWNTO 0)); end component; constant clk_period : time := 1 us;-- 1Mhz clock signal clk, oe: std_logic; signal inp, outp: std_logic_vector (7 downto 0):= "00000000"; signal bidir1: std_logic_vector (7 downto 0):= "ZZZZZZZZ"; begin uut: bidir Port Map (bidir => bidir1, inp => inp, outp => outp, oe => oe, clk => clk); clk_process: process begin clk <= '0'; wait for clk_period/2; --for 0.5 ns signal is '0'. clk <= '1'; wait for clk_period/2; --for next 0.5 ns signal is '1'. end process; test_case: process is begin wait for 500 ns; oe <= '1'; bidir1 <= "ZZZZZZZZ"; inp <= "11111111"; wait for 1000 ns; oe <= '1'; bidir1 <= "ZZZZZZZZ"; inp <= "11111111"; wait for 1000 ns; oe <= '1'; bidir1 <= "ZZZZZZZZ"; inp <= "00000000"; wait for 1000 ns; oe <= '1'; bidir1 <= "ZZZZZZZZ"; inp <= "00000000"; end process test_case; end architecture verify;
