Here's something I'm trying to write to begin:
library ieee;
use ieee.std_logic_1164.all;
entity FrameHolder is
port
clk,reset: in std_logic;
input: in std_logic;
foundframestart : out std_logic;
output: out std_logic
end FrameHolder;
architecture structure of FrameHolder is
signal prehold: std_logic_vector(63 downto 0);
signal frame: std_logic;
signal counter: integer range 0 to 1510;
component preamble
PORT
aclr : IN STD_LOGIC ;
clock : IN STD_LOGIC ;
enable : IN STD_LOGIC ;
shiftin : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (63 DOWNTO 0)
end component;
begin
process(clk,reset,input,frame)
begin
if(reset = '1') then
counter<=0;
elsif(clk'event and clk='1' and frame <= '1') then
counter<=counter+1;
end if;
end process;
pre: preamble port map(reset,clk,not frame,input,prehold);
foundframestart <= '1' when prehold = "1101010101010101010101010101010101010101010101010101010101010101" and counter = 0 else '0';
frame <= '1' when prehold = "1101010101010101010101010101010101010101010101010101010101010101" and counter = 0 else '0';
end structure;
For now, foundframestart and frame are the same thing. I want to know when I've found an ethernet frame and then start counting the next bits after finding the ethernet frame. However, VHDL is getting rid of my signal and thus taking it out of the elsif statement and counter is always being incremented and my output never goes high.
