16 years agoSlight change, the counter still starts too early (it starts right away) because the frame signal is being synthesized away or something.
library ieee;
use ieee.std_logic_1164.all;
entity FrameHolder is
port
clk,reset: in std_logic;
input: in std_logic;
foundframestart : out std_logic;
countout: out integer range 0 to 1510;
output: out std_logic
end FrameHolder;
architecture structure of FrameHolder is
signal prehold: std_logic_vector(63 downto 0);
signal frame: std_logic;
signal counter: integer range 0 to 1510;
component preamble
PORT
aclr : IN STD_LOGIC ;
clock : IN STD_LOGIC ;
enable : IN STD_LOGIC ;
shiftin : IN STD_LOGIC ;
q : OUT STD_LOGIC_VECTOR (63 DOWNTO 0)
end component;
begin
process(clk,reset,input)
begin
if(reset = '1') then
counter<=0;
elsif(clk'event and clk='1' and frame <= '1') then
counter<=counter+1;
end if;
end process;
pre: preamble port map(reset,clk,not frame,input,prehold);
frame <= '1' when prehold = "1101010101010101010101010101010101010101010101010101010101010101" else '0';
foundframestart <= frame;
countout <= counter;
