13 years agoAssuming your processor has an OCI core in it you could try opening a command window and then running `nios2-download` with no options. This should find the processor, pause it then resume it.
If it doesn't then you probably have a problem with the timing or the clocks to your processor (it might be that you have a locked slave but that's less likely)
