13 years agoYou haven't said which of my suggestions you actually tried and what the results where, so it's difficult to help you.
If you are using a development kit I'd suggest to start a new project and add things one at a time. First run the default project with a hello world application and check that the CPU is running and printing something. Then add your component, and check that the CPU is still working and printinf something, before you try to access your component.
