13 years agoDoes anybody have a solution? I am sure that you can try the project I gave to you (If I gave it to you) and see that it won't work.
Also on another note I am wondering about his one issue. The memory controller uses 16 bit data, but my CPU uses 32-bit data. Will the QSYS system detect that issue and add logic to convert 32 data to 16 bit and vice versa, or do I actually have to add customlogic to convert it.
