Altera_ForumHonored Contributor13 years agoBest way to interface my CPU Hello, I am wondering what is the best way to interface my 32-bit RISC CPU. I need to interface it with the sdram memory, the flash memory, and possibly the sram memory. I will also need to dedicate ...Show More
Altera_ForumHonored Contributor13 years ago --- Quote Start --- Is it ok if I just zip the project and then send it? --- Quote End --- a (complete) zip will work too ...
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
