13 years agoI notice that you changed your write address. Are you sure it's correct?
What did you synchronize on in Signaltap? Did you configure a trigger on a rising edge of "write"? Are you still using chipselect in your code? The recommended way is to just use the read and write signals. They will only be asserted for your slave anyway.
