13 years agoI just used signaltap and I can see that the av_readdata_pre in the slave translator (for the test slave) is always 0. I am guessing that the CPU doesn't send the command, or it is disturb on route.
EDIT: I looked at the RTL viewer and I figured out that av_readdata_pre is not needed at all so I have to check again now EDIT2: Can't find anything else to latch onto.
