13 years agoThe issue with the CPU is that I don't actually have the data cache so it should work. I don't know what other issues there could be.
EDIT: I forgot to mention that I changed the slave code a bit, here it is:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity test_slave is
port (
clock : in std_logic;
resetn : in std_logic;
read : in std_logic;
write : in std_logic;
chip_select : in std_logic;
byte_enable : in std_logic_vector(3 downto 0);
writedata : in std_logic_vector(31 downto 0);
readdata : out std_logic_vector(31 downto 0);
to_lights : out std_logic_vector(31 downto 0)
end test_slave;
architecture Behavioral of test_slave is
signal the_register : std_logic_vector(31 downto 0);
begin
process(clock,resetn,read, chip_select)
begin
to_lights <= the_register;
if read = '1' AND chip_select = '1' then
readdata <= the_register;
else
readdata <= (others => '0');
end if;
if chip_select = '1' then
if resetn = '0' then
the_register <= (others => '0');
elsif rising_edge(clock) then
if write = '1' then
if byte_enable(0) = '1' then
the_register(7 downto 0) <= writedata(7 downto 0);
end if;
if byte_enable(1) = '1' then
the_register(15 downto 8) <= writedata(15 downto 8);
end if;
if byte_enable(2) = '1' then
the_register(23 downto 16) <= writedata(23 downto 16);
end if;
if byte_enable(3) = '1' then
the_register(31 downto 24) <= writedata(31 downto 24);
end if;
end if;
end if;
end if;
end process;
EDIT: I would also like to mention that the code comes from an on-chip rom that is initialized with the hex file that Eclispe compiles.
