13 years agoWhat's the reason of manually synthesizing a counter, like you did? The logic synthesizer is supposed to do that boring job.
In VHDL you can simply increment a 11bit count register and take the MSB. For example:
entity divider is
port (CLKIN : in std_logic;
RESET : in std_logic;
CLKOUT : out std_logic );
end entity divider;
architecture divider_2048 of divider is
signal cnt : unsigned(10 downto 0);
begin
process(RESET, CLK)
begin
if RESET = '1' then
cnt <= (others => '0');
elsif rising_edge(CLK) then
cnt <= cnt + 1;
end if;
end process;
Q <= cnt(10);
end architecture divider_2048;
