alexislms
Contributor
3 years agoBest practice to generate and compress a pof file?
I have few questions.
1. I generated a .pfg file from the GUI
* How can I generate the command line from it?
* How can I see the command quartus runs? I'd like to keep only the command line in...
NurAiman_M_Intel
3 years agoHi,
In Agilex userguide mention that
"To reduce configuration file size and support smaller memory sizes, and enable faster configuration, the Intel Quartus Prime software compresses the configuration data. All Intel Agilex devices compress the configuration bitstream. This feature is always enabled. "
Hence the file is already compressed. Except for .sof file, you can manually compress it in Quartus.
Aiman
- alexislms3 years ago
Contributor
It's amazing what the user-guide mentions, but it isn't the case.
Please read again my original question point 3.
Maybe you can verify by yourself by taking an Agilex I-series example design and generate the pof file?!
And then provide a fix for this always enabled non-working feature.
