alexislms
Contributor
3 years agoBest practice to generate and compress a pof file?
I have few questions.
1. I generated a .pfg file from the GUI
* How can I generate the command line from it?
* How can I see the command quartus runs? I'd like to keep only the command line in...
NurAiman_M_Intel
3 years agoHi,
- Kindly refer below for your 1st question;
2.https://www.intel.com/programmable/technical-pdfs/654662.pdf (page 48) -Link to TCL scripting
3.You can compressed the .pof by using convert programming file in quartus. Please refer picture attached.
Aiman
NurAiman_M_Intel
3 years ago- alexislms3 years ago
Contributor
I can't use the Convert Programming file.
Error(20687): Convert Programming Files does not support the target device agib027r29a1e2vr0. Please use Programming File Generator to generate the programming file for the target device.How can I enable pof compression with quartus_pfg not quartus_cpf?
