14 years ago --- Quote Start --- reset: is there a difference between synchronous and asynchronous reset? --- Quote End --- From your point of view they both keep the logic in a reset state. You may see a difference at the time of reset removal: with async reset you must be aware that not all involved registers will come out of reset at the same clock cycle and this could be a problem. So a sync reset is usually preferable. --- Quote Start --- clock enable:not sure if stopping the clock enable signal will save any power :confused: the clock itself is still running... settings the inputs to a constant, the same as clock enable... --- Quote End --- Any switching signal will consume power, so if you limit switching by stopping clocks you definitely spare power. Ideal CMOS-type logic draws no power when it stands still. Remind that a major power consuption derives from output buffers driving external pins, so, if possibile, you can tristate them. Input signals are usually not a great concern, since power is borrowed from an external device. --- Quote Start --- clock: if I stop the clock using a simple AND gate, will it affect timing? must I use a clock control block? (the entire design uses a single clock) will it use another global clock network? --- Quote End --- Gating a clock is a bad practice and it is never recommended. You'd better disable the PLL which generates it.
