11 years agoBasic setup in Quartus
Hi i have demo project running on a eval board with a top.v file as entry. Now i have tried to make a new project to match a custom PCB but the generated top.v does look anything close to the othe...
11 years agoHi Alex just to let you know i think ive solved this part of the problem.
here's the last part of my top level entry.
architecture ppl_type of top is
signal adc_10MHz_clk: std_logic;
signal nios_50MHz_clk: std_logic;
signal pll_locked: std_logic;
signal reset_n: std_logic;
component alt_pll
port
areset : in std_logic;
inclk0 : in std_logic;
c0 : out std_logic;
c1 : out std_logic;
locked : out std_logic
end component;
component CellController
port
clk_clk : in std_logic; -- clk.clk
leds_external_connection_export : out std_logic_vector(3 downto 0); -- leds_external_connection.export
modular_adc_0_adc_pll_clock_clk : in std_logic; -- modular_adc_0_adc_pll_clock.clk
modular_adc_0_adc_pll_locked_export : in std_logic; -- modular_adc_0_adc_pll_locked.export
reset_reset_n : in std_logic -- reset.reset_n
end component;
begin
alt_pll_inst : alt_pll
port map
areset => reset_in,
inclk0 => clk_in_50MHz,
c0 => adc_10MHz_clk,
c1 => nios_50MHz_clk,
locked => pll_locked
CellController_inst : CellController
port map
clk_clk => nios_50MHz_clk,
leds_external_connection_export => LED(3 downto 0),
modular_adc_0_adc_pll_clock_clk => adc_10MHz_clk,
modular_adc_0_adc_pll_locked_export => pll_locked,
reset_reset_n => reset_n
end; now there is just some issues with unconstrained inputs... thanks for the help
