11 years agoBasic setup in Quartus
Hi i have demo project running on a eval board with a top.v file as entry. Now i have tried to make a new project to match a custom PCB but the generated top.v does look anything close to the othe...
11 years agoHi Alex
so i guess this vhdl taken from {My_custom}/syntesis/{My_custom.vhd}--entity CellController is
--port (
-- clk_clk : in std_logic := '0'; -- clk.clk
-- leds_external_connection_export : out std_logic_vector(3 downto 0); -- leds_external_connection.export
-- modular_adc_0_adc_pll_clock_clk : in std_logic := '0'; -- modular_adc_0_adc_pll_clock.clk
-- modular_adc_0_adc_pll_locked_export : in std_logic := '0'; -- modular_adc_0_adc_pll_locked.export
-- reset_reset_n : in std_logic := '0' -- reset.reset_n
--end entity CellController;
needs to fit into auto generated top.vhd -- Copyright (C) 1991-2015 Altera Corporation. All rights reserved.
-- Your use of Altera Corporation's design tools, logic functions
-- and other software and tools, and its AMPP partner logic
-- functions, and any output files from any of the foregoing
-- (including device programming or simulation files), and any
-- associated documentation or information are expressly subject
-- to the terms and conditions of the Altera Program License
-- Subscription Agreement, the Altera Quartus II License Agreement,
-- the Altera MegaCore Function License Agreement, or other
-- applicable license agreement, including, without limitation,
-- that your use is for the sole purpose of programming logic
-- devices manufactured by Altera and sold by Altera or its
-- authorized distributors. Please refer to the applicable
-- agreement for further details.
library ieee;
use ieee.std_logic_1164.all;
library altera;
use altera.altera_syn_attributes.all;
entity top is
port
-- {ALTERA_IO_BEGIN} DO NOT REMOVE THIS LINE!
PSB_ENA : in std_logic;
ADC_PSB1 : in std_logic;
ADC_PSB2 : in std_logic;
ADC_PSB3 : in std_logic;
ADC_PSB4 : in std_logic;
ADC_Vc1 : in std_logic;
ADC_Vc2 : in std_logic;
ADC_7 : in std_logic;
ADC_8 : in std_logic;
RS232_RX : in std_logic;
RS232_CTS : in std_logic;
EXT_ADC2_DATA : in std_logic;
SEL1 : in std_logic;
xEXT_ADC2_CS : in std_logic;
xEXT_ADC2_CLK : in std_logic;
xEXT_ADC1_CS : in std_logic;
xBP_SW_2 : in std_logic;
xBP_SW_1 : in std_logic;
EXT_ADC1_CLK : in std_logic;
xPSB_ENA : in std_logic;
TEMP_CAP2 : in std_logic;
TEMP_CAP1 : in std_logic;
PSB_FAIL : in std_logic;
SEL3 : in std_logic;
EXT_ADC1_DATA : in std_logic;
xPSB_FAIL : in std_logic;
TEMP_PCB : in std_logic;
SEL2 : in std_logic;
RS232_TX : in std_logic;
RS232_RTS : in std_logic;
xEXT_ADC2_DATA : in std_logic;
xTEMP_CAP2 : in std_logic;
xTEMP_CAP1 : in std_logic;
xEXT_ADC1_DATA : in std_logic;
nios_setup_clk_clk : in std_logic;
nios_setup_led_io_external_connection_export : in std_logic_vector(7 downto 0);
nios_setup_modular_adc_0_adc_pll_clock_clk : in std_logic;
nios_setup_modular_adc_0_adc_pll_locked_export : in std_logic;
nios_setup_reset_reset_n : in std_logic;
alt_pll_areset : in std_logic;
alt_pll_inclk0 : in std_logic;
alt_pll_c0 : out std_logic;
alt_pll_c1 : out std_logic;
alt_pll_locked : out std_logic;
LVDS_det : in std_logic;
xEXT_ADC1_CLK : in std_logic;
LVDS_RD : in std_logic;
LVDS_TD : in std_logic;
PWM_S : in std_logic_vector(0 to 3);
GD_FB : in std_logic_vector(0 to 3);
TEMP_SW : in std_logic_vector(0 to 3);
xGD_FB : in std_logic_vector(0 to 3);
xPWM_S : in std_logic_vector(0 to 3);
xTEMP_SW : in std_logic_vector(0 to 3)
-- {ALTERA_IO_END} DO NOT REMOVE THIS LINE!
-- {ALTERA_ATTRIBUTE_BEGIN} DO NOT REMOVE THIS LINE!
-- {ALTERA_ATTRIBUTE_END} DO NOT REMOVE THIS LINE!
end top;
architecture ppl_type of top is
-- {ALTERA_COMPONENTS_BEGIN} DO NOT REMOVE THIS LINE!
component alt_pll
port
c0 : out std_logic;
c1 : out std_logic;
end component;
-- {ALTERA_COMPONENTS_END} DO NOT REMOVE THIS LINE!
begin
-- {ALTERA_INSTANTIATION_BEGIN} DO NOT REMOVE THIS LINE!
alt_pll_inst : alt_pll
port map
areset => alt_pll_areset,
inclk0 => alt_pll_inclk0,
c0 => alt_pll_c0,
c1 => alt_pll_c1,
locked => alt_pll_locked
-- {ALTERA_INSTANTIATION_END} DO NOT REMOVE THIS LINE!
end; im not sure how the clock should be mapped, as of now i mapped nios_setup_clk_clk to (IO_bank2, pin 27)in the pin planner but i should also be mapped to the PLL. ive added a PLL IP-component in the Quartus project and in the Pin-planner but not in Qsys, hope this is correct. thanks in advance... /stefan
