11 years agoBasic setup in Quartus
Hi i have demo project running on a eval board with a top.v file as entry. Now i have tried to make a new project to match a custom PCB but the generated top.v does look anything close to the othe...
11 years agoYou need to instantiate your Nios in the top.v for your new development board. I've done so as an example below.
It looks like your new board has a 50MHz oscillator on it, this is common. So, there's (probably) no need for your PLL. I've removed and just fed your Nios with the 50MHz clock. LED connections are straightforward. I've assumed SEL1-3 are switches on your new dev board (I don't recognise the I/O signal list you posted - which development board is it for?). If they're not you'll need to substitute in signals that are switches (or push buttons perhaps?). I'm not sure why your Nios module would need the 10MHz clock and you should be able to ignore the PLL locked signal you had before - see comments in code. I've not compiled the code - it's just provided for guidance. Let me know how you get on. Cheers, Alexmodule top
// {ALTERA_ARGS_BEGIN} DO NOT REMOVE THIS LINE!
ADC_7,
ADC_8,
ADC_PSB1,
ADC_PSB2,
ADC_PSB3,
ADC_PSB4,
ADC_Vc1,
ADC_Vc2,
BP_SW_1,
BP_SW_2,
CLK50M,
EXT_ADC1_CLK,
EXT_ADC1_CS,
EXT_ADC1_DATA,
EXT_ADC2_CLK,
EXT_ADC2_CS,
EXT_ADC2_DATA,
GD_FB,
LED,
LVDS_det,
LVDS_RD_MINUS,
LVDS_RD_PLUS,
LVDS_TD_MINUS,
LVDS_TD_PLUS,
PSB_ENA,
PSB_FAIL,
PWM_S,
RS232_CTS,
RS232_RTS,
RS232_RX,
RS232_TX,
SEL1,
SEL2,
SEL3,
TEMP_CAP1,
TEMP_CAP2,
TEMP_PCB,
TEMP_SW,
xBP_SW_1,
xBP_SW_2,
xEXT_ADC1_CLK,
xEXT_ADC1_CS,
xEXT_ADC1_DATA,
xEXT_ADC2_CLK,
xEXT_ADC2_CS,
xEXT_ADC2_DATA,
xGD_FB,
xPSB_ENA,
xPSB_FAIL,
xPWM_S,
xTEMP_CAP1,
xTEMP_CAP2,
xTEMP_SW
// {ALTERA_ARGS_END} DO NOT REMOVE THIS LINE!
// {ALTERA_IO_BEGIN} DO NOT REMOVE THIS LINE!
input ADC_7;
input ADC_8;
input ADC_PSB1;
input ADC_PSB2;
input ADC_PSB3;
input ADC_PSB4;
input ADC_Vc1;
input ADC_Vc2;
output BP_SW_1;
output BP_SW_2;
input CLK50M;
output EXT_ADC1_CLK;
output EXT_ADC1_CS;
input EXT_ADC1_DATA;
output EXT_ADC2_CLK;
output EXT_ADC2_CS;
input EXT_ADC2_DATA;
input GD_FB;
output LED;
input LVDS_det;
input LVDS_RD_MINUS;
input LVDS_RD_PLUS;
output LVDS_TD_MINUS;
output LVDS_TD_PLUS;
output PSB_ENA;
input PSB_FAIL;
output PWM_S;
input RS232_CTS;
output RS232_RTS;
input RS232_RX;
output RS232_TX;
input SEL1;
input SEL2;
input SEL3;
input TEMP_CAP1;
input TEMP_CAP2;
input TEMP_PCB;
input TEMP_SW;
output xBP_SW_1;
output xBP_SW_2;
output xEXT_ADC1_CLK;
output xEXT_ADC1_CS;
input xEXT_ADC1_DATA;
output xEXT_ADC2_CLK;
output xEXT_ADC2_CS;
input xEXT_ADC2_DATA;
input xGD_FB;
output xPSB_ENA;
input xPSB_FAIL;
output xPWM_S;
input xTEMP_CAP1;
input xTEMP_CAP2;
input xTEMP_SW;
// {ALTERA_IO_END} DO NOT REMOVE THIS LINE!
// {ALTERA_MODULE_BEGIN} DO NOT REMOVE THIS LINE!
// {ALTERA_MODULE_END} DO NOT REMOVE THIS LINE!
wire nios_50M_clk;
wire reset_n;
wire LED_ctrl_from_nios;
wire SW_to_nios;
assign nios_50M_clk = CLK50M; // Local 50MHz osc on your new board means you don't need your 10MHz->50MHz PLL
assign reset_n = 1'b1; // Just tie reset_n high to take Nios out of reset from the start
assign LED = LED_ctrl_from_nios; // Connect 3 LEDs to your control from your Nios
assign LED = 5'b0; // Tie off unused LEDs
assign SW_to_nios = {SEL3, SEL2, SEL1}; // A guess, assuming SEL1-3 are switches on your dev board. If not you will need to find some.
// Instanciate your Nios module inside the outer 'top' wrapper module for your new dev board.
nios_setup u0 (
.clk_clk (nios_50M_clk), // clk.clk
.reset_reset_n (reset_n), // reset.reset_n
.led_io_external_connection_export (LED_ctrl_from_nios), // led_pio_external_connection.export
.sw_io_external_connection_export (SW_to_nios), // switch_pio_external_connection.export
// Suspect you don't need the following two lines for your application. Either tie off (as below)
// or revisit in Qsys and modify your component to remove them.
.modular_adc_0_adc_pll_clock_clk (1'b0), // modular_adc_0_adc_pll_clock.clk
.modular_adc_0_adc_pll_locked_export (1'b0) // modular_adc_0_adc_pll_locked.export
endmodule
