8 years agoBasic question about Signals
Hi, I'm beginner in VHDL; My Question is ; when we define a signal as std_logic, but without any value. Is it same of saying that signal's starting value is '0' ?
8 years agoThank you for your consideration, I got it and initialized all signals. On testbench wave, I was seeing 'U' at out. now it's fixed. But, At that time my CLK_50Mhz input defined in Entity started to be seen 'U' . Do I have to initialize 'CLK_50Mhz' in entity port as well? Please take a look on my basic code.
entity son is port ( CLK_50MHz: in std_logic; myLED: out std_logic ); end son; architecture behavior of son is signal counter:std_logic_vector(24 downto 0):="0000000000000000000000000"; signal CLK_1Hz:std_logic :='0'; begin --1011111010111100001000000 prescaler: process(CLK_50MHz) begin if rising_edge(CLK_50MHz) then if counter<"1011111010111100001000000" then counter<=counter+1; else CLK_1Hz <= not CLK_1Hz; counter <= (others => '0'); end if; end if; end process prescaler; myLED<=CLK_1Hz; end behavior; That's a basic led blink, On testbench wave, getting CLK_50Mhz = 'U' and myLED = 0. and this's my testbench code( I don't post libraries here to keep the code short.) ENTITY testbench2 IS END ; ARCHITECTURE testbench2_arch OF testbench2 IS SIGNAL CLK_50MHz : STD_LOGIC ; SIGNAL myLED : STD_LOGIC ; COMPONENT son PORT ( CLK_50MHz : in STD_LOGIC ; myLED : out STD_LOGIC ); END COMPONENT ; BEGIN DUT : son PORT MAP ( CLK_50MHz => CLK_50MHz , myLED => myLED ) ; -- "Clock Pattern" : dutyCycle = 50 -- Start Time = 0 ps, End Time = 1 ns, Period = 100 ps clk_50mhz <= not clk_50mhz after 20 ns /2 ; -- "Constant Pattern" -- Start Time = 0 ps, End Time = 1 ns, Period = 0 ps Process Begin if myled /= ('0' ) then report " test case failed" severity error; end if; wait for 1 ns ; -- dumped values till 1 ns wait; End Process; END; THANKS AND BEST REGARDS
