10 years agoBad Performance of Host to OpenCL Memory Transfers
I'm working with the Socrates II SoC Cyclone V board and am just getting started. After trying a few basic examples I noticed very low performance for an integer division test. It was almost as slow ...
10 years agoI did some more tests, here are the results:
Memory read test kernel (Read array of integers and compute XOR): ~2.1GB/s Memory write test kernel (Write consecutive integers into an array): ~2.0GB/s Host memory test (memcpy): ~1.5GB/s To clarify: The extremely low performance is caused by the clEnqueueReadBuffer and clEnqueueWriteBuffer calls. These calls block even though I pass CL_FALSE to the blocking_write/blocking_read parameter. CPU usage is also high during these operations. Is this simply an ALTERA OpenCL bug?
