11 years ago
Backspace character in System Console
I am testing some memory using System Console and I would like to make a simple progress bar which will show current progress. For that I would need a backspace character.
The Tcl interpreter from Centos 7 works as expected:
$ tclsh
% puts $tcl_version
8.5
% puts "abc\bd"
abd
But System Console gives this:
% puts $tcl_version
8.5
% puts "abc\bd"
abcd
Is there any way I can delete current characters or maybe whole line in System Console?
    Probably not. System Console is a very crippled console interface which I believe is based on Jacl (a Java TCL interpreter).
    You might be better off looking at the Dashboard widgets and see if you can use a progress indicator there.
    Cheers,
    Dave
    The solution is so simple that I am almost ashamed to post it. You don't have to delete anything if you dont print anything, so for a very simple progress bar it is enough to print a character on the right iterations.
    Here is the code:
    set BAR_LEN 50
    #  Puts top line
    proc put_top_line { } {
    	global BAR_LEN
    	puts -nonewline "|"
    	for {set i 0} {$i < $BAR_LEN} {incr i} {
    		puts -nonewline "-"
    	puts -nonewline "|\n"
    #  Puts#  to fill the progress bar, should be called every loop iteration
    proc put_filler {cur max} {
    	global BAR_LEN
    	if {  } {
    		puts -nonewline "|"
    	} elseif {  } {
    	} else {
    		set curValue
    		set nextValue
    		if {  } {
    			puts -nonewline "#"
    #  Test
    put_top_line
    for {set i 0} { $i < 1000 } { incr i } {
    	put_filler $i 999
    	after 10
