12 years ago
Average using nbit numbers add them together and divide by n bit number
This is my main code and i have the module for divider
i think the divider code works i tested it and no errors. but I'm not sure if it divided. I got this far and feel lost im not sure where to go from here.
module Adder (A1, B1, Cin,Q);
  parameter n = 5;
  outputQ;
  reg Q;
  input  A1;
	wire A1;
  input  B1;
	wire  B1;
input Cin;
  always @(A1 or B1 or Cin)
begin
    Q = A1 +B1 + Cin;
end
endmodule
module ave(Clk,X,LA,DataA,Sum,Q);
parameter n=5;
input A,B,EB,Temp,DataA,DataB,Sum,Q;
input X;
reg A,B,Temp,Sum;
reg y,Y
wire
reg S1=3'b000;S2=3'b001;S3=3'b010;S4=3'b011;S5=3'b100;
always (Clk)
begin
case(y)
S1:
	 y=S2;
S2:
	 y=S3;
S3:
if (counter>0) y=S2;
	else y=S4;
S4:
	y=S4;
S5:
	Done;
endcase
end
always (Clk)
begin
case
S1:
	Counter=n; Temp=n; Sum=0;
S2:
	A=X;
S3:
if (counter>0) B<=A+B;
	else B<=B;
S4:
	DataA=Temp;
	DataB=Sum;
S5:
	Done=1;
end
Adder add(A,Sum,Cin,Sum);
divider divid(Clk,1,1,1,1,DataA,DataB,1,1,Q,0);
endmodule
This is my divider it has like 4 other modules which might not be correct any help is appreciated
module shiftlne(R,C,L,w,Clk,Q);
parameter n=8;
input R;
input L,w,Clk,C;
output Q;
reg Q;
integer k;
always @(posedge Clk)
begin
	if(L)begin
		if(C)begin
	Q<=R;end
	else
	begin
	for (k=0;k<(n-1);k=(k+1))
		Q=Q;
		Q<=w;
	end
		end
end
endmodule
module downcounter (R,E,L,Clk,Q);
parameter n=8;
inputR;
input Clk,L,E;
output Q;
regQ;
begin	if(L)
		Q<=R;
	else if(E)
		Q<=(Q-1);
end
endmodule
module muxdff(	D0, D1, Sel, Clk,Q);
input Clk,D0,D1,Sel;
wire D;
output Q;
reg Q;
assign D=Sel?D1:D0;
always @ (posedge Clk)
begin
		Q=D;
end
endmodule
module regne (R,Clk,Resetn,E,Q);
parameter n=8;
input R;
input Clk,Resetn,E;
output Q;
reg  Q;
always @(posedge Clk or negedge Resetn)
begin
if (Resetn==0)
	Q<=0;
else if (E)
 Q<=R;
end
endmodule
module divider (Clk,Resetn,s,LA,EB,DataA,DataB,R,Q,Done);
parameter n=8 ;
parameter logn=3;
input Clk,Resetn,s,LA,EB;
inputDataA,DataB;
output R;
outputQ;
output Done;
reg Done;
wire Cout,z,R0;
wire DataR;
wire Sum;
reg y,Y;
wire A,B;
wire Count;
reg EA,Rsel,LR,ER,ER0,LC,EC;
integer k;
parameter S1=2'b00,S2A=2'b01,S2B=2'b10,S3=2'b11;
always @(s or y or z or Cout)
begin
	case(y)
	S1:
	 if(s==0) Y=S1;
		else if(Cout==1) Y=S2A;
		else y=S2B;
	S2A:
		 if(z==0)
		begin
			if(Cout==1)
			 begin
				Y=S2A;
			 end
			else
			 begin
				Y=S2B;
			 end
		end
		else begin Y=S3; end
	S2B:
	 if(z==0)begin
		if(Cout==1)begin Y=S2A;end
			else begin Y=S2B;end
		end
		else begin Y=S3;end
	S3:
	 if (s==1)begin Y=S3;end
		else begin Y=S1;end
endcase
end
begin:FSM_outputs
EA=0;Rsel=0;LR=0;ER=0;ER0=0;LC=0;EC=0;Done=0;
case(y)
S1:
begin
	Rsel=0;LR=1;ER0=0;LC=1;
end
S2A:
begin
	EA=1;Rsel=1;LR=1;ER0=0;
end
S2B:
begin
	EA=1;Rsel=1;ER=1;ER0=1;
end
S3:
begin
Done=1;
end
endcase
end
regne RegB (DataB,Clk,Resetn,EB,B);
	defparam RegB.n=n;
shiftlne ShiftR(DataR,LR,ER,R0,Clk,R);
	defparam ShiftR.n=n;
muxdff FF_R0(1'b0,A,ER0,Clk,R0);
shiftlne ShiftA(DataA,LA,EA,Cout,Clk,A);
	defparam Counter.n=logn;
	assign Q=A;
downcounter Counter(Count,EC,LC,Clk,Count);
	defparam ShiftA.n=n;
	assign z=(Count==0);
	assign Sum ={1'b0,R,R0}+{1'b0,~B}+1;
	assign Cout= Sum;
begin
	if(Resetn==0)begin
		y<=S1;end
	else begin
		y<=Y;end
end
endmodule
    May I suggest you've added a little too much code without a clear explanation of your issue. If you still have an issue perhaps you could be a little more specific and we can see if we can be of any help :)
    I've managed to clean up the code big time. I understand I was super vague. I guess my main problems are with modules inputs and outputs. When I'm using a module can I loop my input as my output. Also can I set reg's equal to each other if so where can I do that. I'm have a lot of trouble because it did not like my assignments so i tried to make everything modules and tried to only chang in enables and clears but I'm still having issues
