Avalon MM SLVERR(Slave Error) detail explanation.
- 3 years ago
Yes, that's right. Other conditions will be like 1) Address or Data Errors if the endpoint agent receives an invalid or unrecognized address or data during a transaction. 2) Command issue protocol violations. 3) The endpoint agent itself may have internal error.
Sheng
Probably both wr and rd response will not get overlap. Check the document page 34:
Because the read and write interfaces share the response signal, an interface cannot issue or accept a write response and a read response in the same clock cycle.
Check also the timing diagram in page 35.
Sheng
Hi Sheng,
I got your point but my question is different.
is it possible to have a discussion over call based on your availability?
Please provide me your availability schedule so we can have a meeting.
Thanks & Regards
Basavakiran Hiremath
