Avalon MM SLVERR(Slave Error) detail explanation.
- 3 years ago
Yes, that's right. Other conditions will be like 1) Address or Data Errors if the endpoint agent receives an invalid or unrecognized address or data during a transaction. 2) Command issue protocol violations. 3) The endpoint agent itself may have internal error.
Sheng
Hello Sheng,
thanks for providing details.
I have one more doubt with "response".
in Avalon-MM writeresponsevalid and readdatavalid are different lines. if both are working parallel then response will get overlap so in that condition which operation response need to give higher priority?
eg: 1st I received a rd cmd with burstcount of 10 at 1st clock, from 2nd clock to 5th clock there will be a write cmd.
we are getting readdata and readdatavalid from 4th clock to 14th clock. as per specification writeresponsevalid need to sent next to wr transaction completion so writeresponsevalid need to sent at 6th clock. in this condition both wr and rd response will get overlap?
this is the senario you can consider.
Thanks & Regards
Basavakiran Hiremath
