Aswinkrishnan
3 years agoAvalon mm Master BFM
I have being trying to do bus simulation on my avalon slave with avalon mm master bfm.
The simulation output is wrong. For example when I write to an address c0 and write data into it, but not writ...
ShengN_altera
3 years agoHi,
Since the BFM push command had been tested before without any problem. Seems like the problem is on the custom slave. I mean before is what will happen if you modify the custom slave device with an 8-bit data width and multiple individually addressable 8-bit data registers with adjacent addresses to custom slave device with an 8-bit data width and single addressable 8-bit data registers?
Sheng
