Avalon mm Master BFM
Seems like there's no problem with slave translator av_write. The av_write should be connected to slave_0_avalon_slave_0_write and slave_0_avalon_slave_0_write is connected to mm_interconnect_0_slave_0_avalon_slave_0_write. So mm_interconnect_0_slave_0_avalon_slave_0_write by right should be synchronized with av_write. May be you have other initialization in your testbench?
Sheng
The code snippet in the test bench was shared with you earlier (to push a command). That was the set of statements that I use and I believe there are no other initializations elsewhere.
My doubt is that, when I write c0 to a register, why does the interconnect and the slave avs address show a range of addresses such as from c0 to c4, without specifying them?
