Avalon mm Master BFM
I saw when slave_0_address is c0, the slave_0_writedata is ff. Do you mean the slave_0_write is not being asserted? Have you checked that there's proper connection between your avalon slave and avalon mm master bfm.
I think the push a command code should be no problem else master bfm wouldn't have proper waveform.
I notice the master bfm waitrequest, have you enable the Assert waitrequest high for master bfm?
Sheng
I think there is a proper connection between master and the slave. I generated using the qsys. Can we check if it's proper in any other way?
I think I didn't assert waitrequest high but in the waveform, the mo_waitrequest is being asserted towards the end of it right? Is it because not asserting it high?
- Aswinkrishnan3 years ago
In qsys, for the avalon mm master bfm, I had enabled assert wait request high. I had checked it again.
