Aswinkrishnan
3 years agoAvalon MM Master BFM
I have followed the ug_avalon verification example test program and modified it with a custom slave. I have removed the slave thread.
In the test program, the command is written to a randomly gener...
RichardT_altera
3 years agoYou can checkout the example test program here:
There are 3 components connected to BFM master: PIO Control, PIO Status, On-chip RAM
In which the BFM perform read/write to these components in order.
Richard Tan
- Aswinkrishnan3 years ago
Thank you for this example. I tried changing in the test program.sv but only could manage one component at a time, not successively.
I shared that as a VHD file but I am currently working in verilog. I will look in to your example and understand, in the meantime, if there is an example written in verilog, it would be helpful.
Aswin
