Avalon MM Master BFM
Could you help to share the test program's code?
We have a BFM simulation example in the link below. Not sure if it will helps you in anyway.
Richard Tan
- Aswinkrishnan3 years ago
In this test program, I wanted to write a data in to a specific register in the slave and the way it is to be done is by changing the cmd.address
I had modified the test program by removing slave thread.
Now I need the master to write data into the slave in multiple address locations. How can I do that?
Hi
In this test program written in VHDL, instead of generating random aligned address, how can I modify such that the master first send a command to an address and then send another data to another address.
For example
write command data to location between 32'hc0 to 32'hce. and then send another data to a location say 32'h9f.
My slave consists of several components such as a pulse sample interface, laser drive, sequencer etc.
I need to execute each in an order. Can I do that?
Aswin
