16 years agoavalon fifo issue - module dependency loop
I have an Avalon ST-MM FIFO implemented in SOPC. After programming the FPGA, the first time I use NIOS to touch the FIFO CSR (init, clear, read, or whatever) the system hangs. If I then stop the NIOS...
9 years agoHi coverman,
I got the same issue but between Altera_UP_SD_Card_Avalon_Interface_0 and DDR SDRAM Controller. Do you have solution now??
