16 years agoAutomatically open as ATTACHED window
Hi all, I've just installed Quartus II 10.0 and SP1 and I've found that everything (like programmer etc.) is opening as a detached window. It is quite useful to be able do detach the window, but I personally prefer to have everything attached. The problem is, that I am unable to find where to disable this feature. For example when I open Quartus Help for the options of the Programmer, there is written that in the Options dialog box should be these checkboxes:
Show checksum without usercode Initiate configuration after programming Display message when programming finishes Enable real-time ISP to allow background programming Halt on-chip configuration controller Automatically check the Program/Configure checkbox when adding SOF Configure volatile design security key for Stratix III devices Use bitstream compression to configure devices when available Automatically open as detached window PFL / enhanced SFL run CRC check for faster verification Use enhanced Serial flash Loader (SFL) IP as factory default image Check block CRCs to accelerate PFL/SFL verification when available Unprotect EPCS devices selected for the erase/program operation But when I open the Options dialog, there are two options missing: Automatically open as detached window PFL / enhanced SFL run CRC check for faster verification The options are the same when the programmer is detached and attached. Am I missing something? I also found that there aren't any registry entries for the Quartus 10.0 anymore, so I cannot find any way how to set this checkbox without a GUI. Is there any configuration file that can be altered to get this work? Martin
