8 years agoAutomatically add qip file from custom qsys component
Hi all, I am trying to achieve a way to add sources files from a megawizard generated IP block which is part of my own Qsys custom IP component. Instead of manually adding all qip contents to m...
8 years agoCan you add them to the list on the Files tab of the Component Editor? Though I think only HDL files can be added there...
