8 years agoAutomatically add qip file from custom qsys component
Hi all, I am trying to achieve a way to add sources files from a megawizard generated IP block which is part of my own Qsys custom IP component. Instead of manually adding all qip contents to m...
8 years ago --- Quote Start --- Hmm, I've never even thought of adding other IP to a custom component design. Usually I just take HDL code that I want to work in a Platform Designer system and turn it into a custom component, then connect the custom component to other IP/components. I think option 3 is the only thing you can do. Is there a reason why you can't pull those IP out of your custom component and connect to them? --- Quote End --- Hi, Yes normally the way is much easier. But this time I made a quite complex component (a SATA host controller which uses a PHY and xcvr reconfig). Originally i had these two components separately in my qsys but then I came to the conclusion that my linux driver for this IP needed to control several parameters available through the management slave interfaces. Therefore I customized the whole to one IP block.... which is also a more logical approach... And I thought there would be an "advanced newbie" way to add the generated files to my custom design. Regards Henk
