8 years agoAutomatically add qip file from custom qsys component
Hi all, I am trying to achieve a way to add sources files from a megawizard generated IP block which is part of my own Qsys custom IP component. Instead of manually adding all qip contents to m...
8 years agoHmm, I've never even thought of adding other IP to a custom component design. Usually I just take HDL code that I want to work in a Platform Designer system and turn it into a custom component, then connect the custom component to other IP/components. I think option 3 is the only thing you can do.
Is there a reason why you can't pull those IP out of your custom component and connect to them?
