8 years agoAutomatically add qip file from custom qsys component
Hi all, I am trying to achieve a way to add sources files from a megawizard generated IP block which is part of my own Qsys custom IP component. Instead of manually adding all qip contents to m...
8 years agoIf you add the .qsys file to your Quartus Project instead of a .qip, the system will get regenerated whenever you compile the project, incorporating any changes you've made to your custom component. Is that what you're trying to achieve? It's not clear.
