HenryMittel's avatar
HenryMittel
5 years ago
auto-generated file "is missing"
I created a copy of a working design (because I need to move to the newer Arria 10 family), modified the Qsys (because it uses hard-IP that is different for the new family), adapted the wrapper for t...
  • HenryMittel's avatar
    HenryMittel
    5 years ago
    Hello sstrell,
    Thank you for explaining the difference between including .qsys and .qip in the settings file. I thought the "IP Regeneration Policy" under "IP Settings" in Assignments | Settings would decide about that.
    While your answer wasn't directly helpful, it prompted me to take an Nth look at the IP Settings page ... and give "Verilog" instead of "VHDL" another try. I also turned off the regeneration and manually regenerated (as Verilog) the system in the Qsys designer. Now, the errors with the auto-generated files are gone - and I can start working on the errors I introduced.
    And yes, I am still using the old Quartus 15.0 - because I was told that my RapidIO license, whose maintenance expired in 2015, can only be used with Quartus 15 or earlier. Should I question that advice?
    Thanks for the assistance with the original problem.
