Attempting to simulate AXI3 Master BFM in Qsys system. "Library mgc_axi_master_10611 not found."
May I know what error that you are seeing right now? As you mention Error vsim-8388 does not appear anymore.
Yes, usually, we would recommend to use the design example base on Quartus specified and move on from there.
The errors are shown in the transcript file above. It is mostly many repeated instances similar to the following:
# ** Error: (vsim-3193) Load of "C:/intelFPGA_pro/18.1/ip/altera/mentor_vip_ae/common/questa_mvc_core/win32_gcc-4.2.1/libaxi_IN_SystemVerilog_MTI_full.dll" failed: DLL dependent library not found.
# ** Error: (vsim-8649) Initialization function 'axi_IN_SystemVerilog_load' not found.
This is very strange because C:/intelFPGA_pro/18.1/ip/altera/mentor_vip_ae/common/questa_mvc_core/win32_gcc-4.2.1/libaxi_IN_SystemVerilog_MTI_full.dll does exist on the machine. Modelsim is just unable to load it for some reason.
