JHert3
7 years agoAttempting to simulate AXI3 Master BFM in Qsys system. "Library mgc_axi_master_10611 not found."
I'm trying to use the "Mentor Graphics AXI3 Master BFM (Intel FPGA Edition)" IP Core in a simulation. I have used Qsys to generate a VHDL simulation model for the system. Then I am trying to use Mode...
KennyT_altera
7 years agoCan you try the modelsim starter edition? https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
If you are using Q18.1 you need to simulate with the modelsim that support Q18.1.
Modelsim starter edition require no license, the example should work because I had try it in the older version and with Modelsim starter edition.
