JHert3
7 years agoAttempting to simulate AXI3 Master BFM in Qsys system. "Library mgc_axi_master_10611 not found."
I'm trying to use the "Mentor Graphics AXI3 Master BFM (Intel FPGA Edition)" IP Core in a simulation. I have used Qsys to generate a VHDL simulation model for the system. Then I am trying to use Mode...
JHert3
7 years agoHi Kenny
Thanks for your response. Apologies for the delay, a technical issue prevented me from accessing the forum. My design files are attached.
The same error occurs when I try to run the design example you have provided. I am using Quartus Prime Pro 18.1, but simulating with ModelSim-Altera for Quartus II 14.1 as I'm waiting for a license for a ModelSim-IntelFPGA. Is this a likely cause of the issue?
