11 years ago --- Quote Start --- Hi Outku, Thanks for the reply and for your advice. Actually, I have contacted Altera's support yesterday and they suggested the same: a clean install of Quartus 14.1, which I did. Unfortunately, tough the error message changes slightly, the problem seems to remain (c.f. screenshot attached). By the way, support member pointed out that environment variables needed to be set correctly, which I checked successfully (ALTERAOCLSDKROOT, QSYS_ROOTDIR and QUARTUS_ROOTDIR). David --- Quote End --- did you try to rebuild .aocx and rerun the host to produce profile.mon with 14.1? Or, did you just do "aocl report" with the 14.1 using your 14.0 old files? I tried the jpeg_decoder here with 14.1 and the profiler works as expected.
