11 years agoThanks for your answers!
Regarding "create_generated_clock": Excuse my ignorance, but in which TCL file would I have to add these commands? Furthermore, by what I was able to find online, I understand that create_generated_clock needs a source clock. So is ripple_counter:my_counter|t_ff:\remaining_ff:1: create|q_out~reg0 the source of ripple_counter:my_counter|t_ff:\remaining_ff:2: create|q_out~reg0 and so forth? Could anybody give me a hint about how to write the complete create_generated_clock command? This is the updated code of the ripple-counter and the T-flip-flop (incorporating the advise by Tricky):
entity t_ff is
port (
-- Input ports
q_in : in std_logic;
rst : in std_logic;
-- Output ports
q_out : out std_logic
end entity t_ff;
architecture logic of t_ff is
signal internal_q : std_logic := '0';
begin
q_out <= internal_q;
process(q_in, rst, internal_q)
begin
-- Reset=1 sets the flip flop to 0.
if rst = '0' then
if falling_edge(q_in) then
internal_q <= not internal_q;
end if;
-- reset = 1
else
internal_q <= '0';
end if;
end process;
end architecture logic;
entity ripple_counter is
generic (
bit_length : integer := 26
port (
-- Input ports
clock : in std_logic;
reset : in std_logic;
run_counter : in std_logic;
-- Output ports
q : out std_logic_vector((bit_length-1) downto 0)
end entity ripple_counter;
architecture logic of ripple_counter is
component t_ff
port (
rst : in std_logic;
end component;
-- Input bit for first t_ff.
signal q_0 : std_logic := '0';
signal internal_q : std_logic_vector ((bit_length-1) downto 0);
begin
q <= internal_q;
-- Create first T-FlipFlop.
first_ff: t_ff port map (q_0, reset, internal_q(0));
-- Create (bit_length-2) T-FlipFlops.
remaining_ff: for i in 1 to bit_length-1 generate
create: t_ff port map (internal_q(i-1), reset, internal_q(i));
end generate;
process(clock, run_counter)
begin
if run_counter = '1' then
q_0 <= clock;
else
q_0 <= '0';
end if;
end process;
