9 years agoAsynchronous pulse generator code rising edge
Newbie here. I need to generate pulses at rising/falling edges of an input signal. I would like to avoid using an internal clock for this application because parts of my system is inherently as...
9 years agoWhen you say you are failing, what is actually failing? This code looks OK for simulation, but not synthesis in Quartus. You can't synthesize time delays.
