16 years ago
Asynchronous load
This is a shift register question that I'm looking to get some light shed on. I have a 4 16bit shift registers that I'm using to detect a pattern. I feed bits into the shift regs until they match a pattern, at which point I replace the entire contents of the 4 shift registers with something else in a parallel load. The problem is that on one cycle, the pattern is detected and on the next clock cycle, the parallel load occurs. But also occurring on this cycle is the normal serial load. So the parallel load and the serial load collide and the parallel load seems to win and the 4 bits that I wanted to be shifted in serially are lost. Is it possible to do the comparison and load on the same cycle so that the first set of 4 bits on the serial input don't get lost? Is there a special shift register setting for this?
There's a setting for asynchronous load in lpm_shiftreg but its greyed out
