9 years agoAsynchronous Data Pulse Acquisition
Hi altera gurus, First time poster here. I've been teaching myself about writing VHDL, timing analysis, and test benches over the past few months while making a customized DSP application ...
9 years ago --- Quote Start --- To understand if the timing constraint is correct, we should see the logic it's applied to. I think that the problem of reading 5 ns pulses into a 50 MHz clock domain would be usually solved by a toggle synchronizer. --- Quote End --- The logic it's used for is a flancter. I'm not sure if that answers the question you're asking, though. I'm not able to use a toggle synchronizer here because I don't actually have access to the clock domain these pulses are coming in at (they're from an external instrument), so I can't put in the required FF on the faster domain.
