9 years agoAsynchronous Data Pulse Acquisition
Hi altera gurus, First time poster here. I've been teaching myself about writing VHDL, timing analysis, and test benches over the past few months while making a customized DSP application ...
9 years agoDepending on your chosen device, speed grade and how fast it can comfortably be clocked, I'd consider option 2 and use a PLL to generate the higher clock. The downside, you're obviously going to be clocking more logic at a much higher frequency, even if you do the bare minimum before moving everything onto a clock domain operating at a lower frequency.
However, I see nothing wrong with option 1 - the clear advantages of operating only a handful of registers at the higher clock frequency. I think the only correction to the constraint you posted is to specify the period at 5 ns (not 20ns) - as you mentioned, the effective frequency of these 'clocks' is 200MHz. Cheers, Alex PS. Just spotted Cyclone V - which should have no real issues solving this with a PLL.
