11 years agoIt sounds to me like you could have a counter clocked by your asynchronous clock along with a combinatorial comparison for the limit. The limit output would then go through a synchronizer to the FSM clock domain. Similarly, your decrement flag would come from the FSM domain and then be synchronized in the async clock domain. That means the decrement would be delayed by two async clock edges, but that should be fine.
Create a simulation using Modelsim. That way you can try with two fixed frequency clocks, eg., 1MHz and 5MHz, and then once you have the logic working, you can try a variable clock signal in the asynchronous domain and see that it really works just like a fixed clock. The main thing is that in real hardware, you'll want to make sure your async clock does not have runt high or low times, but it sounds like you've already got that under control. Cheers, Dave
