11 years agoAssignments for vectors inequal in length
let's t and d - unsigned vectors and they have different length, and perhaps reverse range
does assignment t := to_unsigned(to_integer(d), t'length) right? what is regular way?5 Replies
--- Quote Start --- let's t and d - unsigned vectors and they have different length, and perhaps reverse range does assignment t := to_unsigned(to_integer(d), t'length) right? what is regular way? --- Quote End --- Not sure about your syntax or reverse range but generally your concept of conversion is right in theory but problematic in practice. You need to make sure that integer will fit... so best is use resize (sign extension) and for unsigned just add zeros to extra MSBs. If going down in bits you need to control what to do with remaining bits; do you chop off LSBs or MSBs and what does it imply for your design. so a general universal assignment is not realistic. - Altera_Forum
integers are limited to 32 bits signed (31 bits unsigned), so this way is not universal.
You also would never have a reverse range unsigned value. The result of any arithmatic will always be (N downto 0). So it doesnt really matter how you declare it - the left bit is always the MSB. it would be much easier just to use the resize function: t := resize(d, t'length); - Altera_Forum
good. I pointed it - have proper declarions.
what will be in case of d'length > t'length ? what will be on truncation of d : a) d(d'left downto d'left-t'length+1) or b) d(t'length+d'right-1 downto d'right) ? i will try avoid using assignment with result truncation until it is really needed. - Altera_Forum
Basically, you drop the MSBs
-- Id: R.1 function RESIZE (ARG: SIGNED; NEW_SIZE: NATURAL) return SIGNED; -- Result subtype: SIGNED(NEW_SIZE-1 downto 0) -- Result: Resizes the SIGNED vector ARG to the specified size. -- To create a larger vector, the new bit positions -- are filled with the sign bit (ARG'LEFT). When truncating, -- the sign bit is retained along with the rightmost part. -- Id: R.2 function RESIZE (ARG: UNSIGNED; NEW_SIZE: NATURAL) return UNSIGNED; -- Result subtype: UNSIGNED(NEW_SIZE-1 downto 0) -- Result: Resizes the UNSIGNED vector ARG to the specified size. -- To create a larger vector, the new bit positions -- are filled with '0'. When truncating, the leftmost bits -- are dropped. - Altera_Forum
Now it is clear. Thanks a lot
