9 years ago
Assigning XCVR_RECONFIG_GROUP constraint to transceiver's differential lane
I am testing Diaplay Port I/P on Altera's Arria 10 board. My top module has the following I/Os
rx1_l0_p
rx1_l1_p
rx1_l2_p
rx1_l3_p
rx1_l0_n
rx1_l1_n
rx1_l2_n
rx1_l3_n
tx1_l0_p
tx1_l1_p
tx1_l2_p
tx1_l3_p
tx1_l0_n
tx1_l1_n
tx1_l2_n
tx1_l3_n
I need to make pin assignments to them and assign "HIGH SPEED DIFFERENTIAL I/O" constraints to them in QSF.
Here, Quartus fitter takes compliment pin assignment automatically. That means, I have to assign PIN assignments to *_P pins only,
if I assign "HIGH SPEED DIFFERENTIAL I/O" constraints to *_P pins. But doing so, it generates *_P(n) pins.
But I don't want that. Please note that I can't change my top module or it's I/Os.
So, instead of letting Quartus automatically assign compliment differential pin, can I assign the pins manually. Like this?
set_location_assignment pin_aw7 -to rx1_l0_p
set_location_assignment pin_aw8 -to rx1_l0_n
set_instance_assignment -name io_standard "high speed differential i/o" -to rx1_l0_p
set_instance_assignment -name io_standard "high speed differential i/o" -to rx1_l0_n
Second question
The above mentioned I/Os are transceiver channels. In Altera's reference design, they have following I/Os
rx1_l0
rx1_l1
rx1_l2
rx1_l3
tx1_l0
tx1_l1
tx1_l2
tx1_l3
Here, they have drawn out only positive ends of differential I/Os
And they have put each TX-RX channel pair under one XCVR_RECONFIG_GROUP
set_instance_assignment -name xcvr_reconfig_group 1 -to tx1_l0
set_instance_assignment -name xcvr_reconfig_group 1 -to rx1_l0
set_instance_assignment -name xcvr_reconfig_group 2 -to tx1_l1
set_instance_assignment -name xcvr_reconfig_group 2 -to rx1_l1
set_instance_assignment -name xcvr_reconfig_group 3 -to tx1_l2
set_instance_assignment -name xcvr_reconfig_group 3 -to rx1_l2
set_instance_assignment -name xcvr_reconfig_group 4 -to tx1_l3
set_instance_assignment -name xcvr_reconfig_group 4 -to rx1_l3
In my top module, both (_P and _N) ends of differential I/Os have been drawn out
RX1_L0_P
RX1_L1_P
RX1_L2_P
RX1_L3_P
RX1_L0_N
RX1_L1_N
RX1_L2_N
RX1_L3_N
TX1_L0_P
TX1_L1_P
TX1_L2_P
TX1_L3_P
TX1_L0_N
TX1_L1_N
TX1_L2_N
TX1_L3_N
What should I write in QSF to put TX-RX pair under same XCVR_RECONFIG_GROUP?
1 Reply
    With Altera's tools you only code and constrain the positive half of differential signals. By virtue of the fact you're specifying the signals as a differential I/O standard Quartus will automatically assign the negative pin accordingly.
    So, no. You shouldn't be adding the constraints you listed. Code for "RX1_L0", for example. Then, in the constraints editor, by specifying this is a differential I/O standard it'll automatically create the assignment for negative pin when you specify the pin for the positive pin.
    I recommend you play around with the 'Pin Planner', with a simple project, exploring the I/O standards and see what .qsf entries result. I think that'll clear things up for you and help answer your second question too. Then you can write your .qsf file from scratch - if you wish.
    Cheers,
    Alex
